Select a reference system for model position in the animation. The reference system is stationary, and you can view
how the the model moves relative to the system.
Review forming outcomes through the Analysis Explorer.
View Feasibility Results
Select the run and load case for the feasibility analysis, then view the results.
View Tryout Results
Select the run and load case for the tryout analysis, then view the results.
Animate and Record Results
Use the Animation Toolbar that appears at the bottom of the modeling window to animate and record results.
Add a Reference System
Select a reference system for model position in the animation. The reference system is stationary, and you can view how the the model moves relative to the system.
Add Callouts to the Results
Call out and review values for a selected result type at points of interest on your model using the callout icons in the Analysis Explorer.
Compare Results in a Table
Compare the results of multiple analysis runs in a table. The Compare Results button is located at the bottom of the Analysis Explorer.
Create and View a Tracer
Use the Tracers tool to visualize the path of a trace point during a forming run.
