Select a reference system for model position in the animation. The reference system is stationary, and you can view
how the the model moves relative to the system.
Select the run and load case for the feasibility analysis, then view the
results.
On the Feasibility tab, Analyze icon, click Show Analysis
Results.
The Analysis Explorer dialog opens.
Tip: Use the
chevron next to each option to view all
options for runs, operations, and result types.
Select a run to analyze.
Select an operation. If you enabled Springback in the
Run Options, it is available as an operation to
select.
Select a result type.
Result Type
Thinning
Thinning is the ratio of the change in thickness to the original
thickness expressed as a percentage. A positive thinning percentage
indicates a reduction in thickness, which could be of concern for the
performance of the part under fatigue loading since thinner regions in
the part will undergo higher stresses compared to the rest of the part.
A negative thinning percentage indicates thickening of the part in
regions of compression. Excessive compression may lead to wrinkles on
the sheet metal, resulting in poor surface quality.
Thickness
Thickness is the actual material thickness distribution in the part.
The thinning percentage is directly derived from the thickness
distribution.
Formability
Formability describes the principal strains on the surface of the
sheet metal, also known as Major and Minor strains, which are
plotted against a Forming Limit Curve to identify the different
deformation zones that occur during the stamping process. Each color
indicates a unique deformation zone during stamping.
Red: High potential for failure from
splitting due to excessive deformation.
Yellow: Marginal potential for
failure.
Green: Safe with no potential for
failure.
Blue: Material is compressed.
Violet: Wrinkling zone with potential for
failure.
Cyan: Loose metal zone indicates that
material is not sufficiently deformed.
When you choose this option, if Shell solution is selected in the
Preferences, a field appears for you to view results based on a
particular material surface. Under Result Types, from the
Formability dropdown, select a surface:
Lower, Upper, or
Membrane (middle).
Major Strain
Major strain is the principal strain on the surface of the sheet
metal due to the deformation of the initial blank shape to the finished
product. The red areas indicate greater stretching relative to the blue
areas.
in the Preferences, a field appears for you to view results based on
a particular material surface. Under Result Types, from the Major
Strain dropdown, select a surface: Lower,
Upper, or Membrane
(middle).
Minor Strain
Minor strain is the principal strain on the surface of the sheet
product. The red areas indicate less compression relative to the blue
areas.
the Preferences, a field appears for you to view results based on a
particular material surface. Under Result Types, from the Minor
Upper, or Membrane
(middle).
Effective Strain
Effective strain is the strain on the surface of the sheet due to
the deformation of the initial blank shape to the finished product. The
red areas indicate more deformation relative to the blue areas.
When
particular material surface. Under Result Types, from the Effective
Upper, or Membrane
(middle).
Press Tonnage
Press tonnage is the force needed to form the part.
Displacement
For a draw or crash form operation, displacement is the distance
that the flat blank moves from its initial shape to its final shape. For
a springback operation, displacement is the distance that the final
blank shape moves back toward its intial shape. Choose the
Magnitude, Global
X,Y,
Z, or +/-
Magnitude.
+/- Magnitude is available for the
springback operation only. Positive magnitude indicates displacement
along the normal direction; negative magnitude indicates
displacement in the opposite direction of the part
normal.
Figure 1. Example Feasibility Results Showing Deformation Zones Figure 2. Example Feasibility Results for Thinning
Enable the various Show options to
determine what is visible for the analysis.
Option
Show/Hide Initial Shape
Show/hide the initial shape as a reference.
Show/Hide All Loads and
Supports
Show/hide loads and supports. You can also show only the
current loads and supports.
Show/Hide Deformed State
Show/hide the deformed shape as a reference.
Show/Hide Contours
Show/hide contours.
Options
Interpolate during animation:
Animate the result contour.
Blended contours: Toggle
between blended and nonblended contours.
Element contour: Show
contours based on elements rather than nodes. This
option is only avaialble for results types that are
based on elements.
Vector plot: Display the
direction vectors for the displacement result
type.
Enable various Callout options to show analysis results
at a point of interest on your model. The callout values apply to the currently
selected run and load case.
Use the Tracer to track how a line moves from one step
to another. For more information, see Trace on a Feasibility Analysis.
View and record the animation of the forming results with the Animation toolbar
that is located at the bottom of the modeling window:
The flattened blank shape is available as IGES and
DXF files in your run directory.
Tip:
Change the legend colors for each result type in the Preferences dialog by clicking > Legend Colors.
To filter the results so that areas on the model with results greater than a
specified value are masked, click and drag the arrow on the results slider.
To mask areas with results less than the specified value, click and select Flip Mask.
Select the arrow to enter a specific value.
Restore the result slider's default values by clicking .
