Adjust the die to counter the known springback in a formed shape.
Tip: Die Compensation is generally an iterative process. For best results,
each time you apply the die compensation process, review the results of the
compensated die for negative draft. In the
Model Browser,
toggle among compensated dies for comparison; choose the option that best suits your
design and build needs. See
Change the Part Alternative for
more information.
