Publish Reports
Generate a report as a .pdf file from the results of a completed simulation.
- From the Run History window, select a completed run.
- On the ribbon, click the Tryout tab.
From the Run tools, select the
Report icon.
The Report dialog appears. - For File Name, enter the name for the .ppt file of the report.
- Select the Model Setup and Results information to include in the report. The Results options are the same as those found in the Analysis Explorer.
Click the Publish button.
A report with your specified results is generated as a .ppt file and stored in the same directory as the run history specified in the Preferences.Note: Any user-defined callouts or custom views, such as draw-direction or isometric views, are captured in the report.
