Discretizing the Currents
Discretizing the object or solution space is commonly referred to as meshing. It is a necessary step to solve the integral equations.
![](../../../../images/feko/user_guide/solver_solution_methods/scattering_conducting_body_meshed.png)
Figure 1. The arbitrary shaped conducting body meshed into triangles.
The equation for the discretized currents can then be substituted into the EFIE (Equation 1) to yield:
In Equation 2, the current coefficients represented by are the only unknown quantity.
Before proceeding to the next step, it is necessary to take a closer look at basis functions.
