Solution Methods per Application
A solution method is selected based on the electrical size of a problem, the geometrical complexity and available computational resources.
Solution method is ideally suited to the problem.
Solution method could be used, but an alternative method is better suited to the problem.
<empty space>
Indication that the respective solution method should not be used.
Table 1. The electromagnetic solution methods suited to the various applications.
  Geometrically complex Electrically large
Wire antennas
Microstrip antennas
Aperture antennas
Reflector antennas
Windscreen antennas
Conformal antennas
Broadband antennas
Array antennas
Lens antennas
Radomes
Antenna placement (radiation pattern)
Antenna placement (coupling)
Biomedical
RADHAZ zones
Periodic structures FSS, metamaterials
Scattering with plane wave source (RCS)
Scattering with localised source
EMC/EMI shielding and coupling
Propagation environment
Cable bundle coupling
Waveguide components
Connectors
Microstrip circuits
