Feko is a comprehensive electromagnetic solver with multiple solution methods that is used for electromagnetic field analyses
involving 3D objects of arbitrary shapes.
EDITFEKO is used to construct advanced models (both the geometry and solution requirements) using a high-level scripting language
which includes loops and conditional statements.
Solver methods can be categorized as either source-based methods or field-based methods. Understanding the main differences
between these two categories helps to understand and choose an appropriate solution method for each application.
The Solver includes multiple frequency and time domain solution methods. True hybridisation of some of these methods enables efficient
analysis of a broad spectrum of electromagnetic problems. You can also use more than one solver method for cross-validation
purposes.
Full wave solutions rigorously solve Maxwell's equations without making any assumptions regarding the nature of the electromagnetic
problem. The solution can be either in the frequency or the time domain.
Asymptotic solution methods solve Maxwell's equations, but make certain assumptions regarding the nature of the problem.
Feko provides various high frequency asymptotic solution methods that assume the frequency of interest is high enough that
the structure is much larger than the wavelength.
The windscreen antenna solution method reduces the computational requirements by meshing only metallic elements while analysing
the behaviour of the integrated windscreen antennas within their operating environment. The analysis can take into account
the physical features of windscreen antennas and their surroundings.
Feko offers state-of-the-art optimisation engines based on generic algorithm (GA) and other methods, which can be used
to automatically optimise the design and determine the optimum solution.
CADFEKO and POSTFEKO have a powerful, fast, lightweight scripting language integrated into the application allowing you to create
models, get hold of simulation results and model configuration information as well as manipulation of data and automate
repetitive tasks.
purposes.
Complex feed networks can be simplified by including them as a circuit representation
using general network blocks.
General networks (defined using network parameter matrices) can be used to model a feed
network. These non-radiating networks may be interconnected (cascaded) and excited or loaded
directly at the ports.
The voltages and currents at the ports of these ideal representations of networks may
interact with currents and voltages on parts of the model that are solved using other solution
methods, though no radiation-based coupling is taken into account.
