Field/Current Data
Define field or current data using either far field data, near field data, spherical mode data or PCB current data. The field/current definition is used when defining an equivalent source or a receiving antenna.
- Create a field/current definition
- Create a field/current data definition by either manually defining the field data or by specifying how to import the field/current data from a file. A range of file formats is supported for the import.
- Define an equivalent source or receiving antenna
- Use the field/current data definition in defining either an equivalent source or a receiving antenna.
