Feko is a comprehensive electromagnetic solver with multiple solution methods that is used for electromagnetic field analyses
involving 3D objects of arbitrary shapes.
3D views are used to display and interact with the model. You can zoom, rotate and pan around a 3D model using the keyboard,
mouse or a combination of both. You can use a 3D mouse, specify a view or select specific parts of a model. Multiple 3D
views are supported.
Define field or current data using either far field data, near field data, spherical mode data or PCB current data. The
field/current definition is used when defining an equivalent source or a receiving antenna.
Import far field data from a Feko file (.ffe), external ASCII file or a CST far field scan (.ffs) to create a far field data definition. Use the far field data when defining an equivalent source or receiving antenna.
Import near field data from Feko field on a Cartesian boundary (.efe and / or .hfe), Sigrity input file (.nfd), Orbit / Satimo measurement file (.mfxm) or a CST near field scan (.nfs) to create a near field data definition. Use the near field data definition when defining an equivalent source
Import near field data from a .efe file and / or .hfe file to define a near field data aperture. Use the near field data aperture when defining an equivalent source or
receiving antenna.
Import spherical modes data from a TICRA .sph file or import from a .sph file exported by CADFEKO, to create a spherical modes data definition. Use the spherical modes data definition when defining an equivalent
Define the propagation direction, index scheme and modes to create spherical modes data, Use the spherical modes data
definition when defining an equivalent source or receiving antenna.
Import printed circuit board (PCB) current data from a PollEx radiated emission interface (.rei) file to create a PCB current data definition. Use the current data definition when defining an equivalent source.
Define a medium with specific material properties, import a predefined medium from the media library or add a medium from
your model to the media library.
Defined media can be applied to the model in various ways. Some media settings are applied to regions, others on faces
and wires. The rules for defining media varies between the different solution methods.
Use a periodic boundary condition (PBC) to analyse infinite periodic structures. A typical application of PBC is to
analyse frequency selective surface (FSS) structures.
Create an arbitrary finite antenna array that consists of an array of contributing elements, either with direct feeds for
each element or via indirect coupling, and solve with the efficient domain Green's function method (DGFM).
Use the windscreen tools to define a curved reference surface constrained by a cloud of points, normals and optional U′V′ parameters. The constrained surface is then used as a reference to create a work surface where windscreen layers and curved
parameterised windscreen antenna elements can be created.
Many electromagnetic compatibility and interference problems involve cables that either radiate, irradiate or cause coupling
into other cables, devices or antennas. Use the cable modelling tool and solver to analyse the coupling and radiation.
For a frequency domain result, the electromagnetic fields and currents are calculated at a single frequency or frequency
range. When the finite difference time domain (FDTD) solver is used, the frequency must be specified to convert the native time domain results to the frequency domain.
The excitation of an antenna is normally specified as a complex voltage, but it may be useful to specify the total radiated
or source power instead. The result is then scaled to yield the desired source power level.
A port is a mathematical representation of where energy can enter (source) or leave a model (sink). Use a port to
add sources and discrete loads to a model.
Obtain multiple solutions for a single model using multiple configurations. Multiple configurations remove the requirement
to create multiple models with different solution requests.
Use an infinite plane or half-space to model a ground plane efficiently. The number of triangles in the model is reduced
as the ground plane is not discretised into triangles.
During the design process, the development of a model can introduce a range of issues that can lead to a non-simulation-ready
model. Use the validation toolset to verify that the model is simulation-ready or to search, detect and flag discrepancies.
The default solver used in Feko is the method of moments (MoM) - surface equivalence principle (SEP). Whether a solver is specified per model, per face or per region, depends on the solver in question.
CADFEKO has a collection of tools that allow you to quickly validate the model, for example, perform calculations using
a calculator, measure distances, measure angles and export images.
EDITFEKO is used to construct advanced models (both the geometry and solution requirements) using a high-level scripting language
which includes loops and conditional statements.
Feko offers state-of-the-art optimisation engines based on generic algorithm (GA) and other methods, which can be used
to automatically optimise the design and determine the optimum solution.
CADFEKO and POSTFEKO have a powerful, fast, lightweight scripting language integrated into the application allowing you to create
models, get hold of simulation results and model configuration information as well as manipulation of data and automate
repetitive tasks.
The far field must be defined in spherical coordinates.
On the Construct tab, in the Define group, click the Field/current data icon. From the drop-down list
select Define far field data.
Figure 1. The Define far field data dialog.
Select one of the following file types to import:
Load field data from Feko
Solver (*.ffe) file
Load field data from an external data
file
Loaf field data from a CST far field scan
(*.ffs)
In the File name field, browse to the file
location.
Far field patterns are typically frequency dependent and models with
radiation pattern sources usually have only a single solution frequency. If the
radiation pattern is calculated using a frequency sweep in Feko, the .ffe file contains multiple
patterns.
In the Start from point number field, specify where the
first line occurs in the file for the required pattern.
For example, if a far field pattern was calculated for 50 field directions
in a frequency sweep, the pattern for the third frequency starts at point number
101.
In the Number of theta points field, specify the number
of theta points used in the imported far field.
In the Number of phi points field, specify the number of
phi points used in the imported far field.
The data block number corresponds to the far field data at a specific
frequency.
In the Use data block number field, specify the data
block number that corresponds to the far field data at a specific
frequency.
In the Label field, specify a unique label for the far
field data.
Click Create to define the far field data and to
close the dialog.
