Defining Spherical Modes Data Manually
Define the propagation direction, index scheme and modes to create spherical modes data, Use the spherical modes data definition when defining an equivalent source or receiving antenna.
On the Construct tab, in the
Define group, click the
Field/current data icon. From the drop-down list
select Manually define spherical modes data.
Under Propagation direction, select one of the
following:
- To illuminate the model with modes propagating towards , spherical Hankel function of the first kind, , select Inward.
- To illuminate the model with modes propagating towards , spherical Hankel function of the second kind, , select Outward.
In the Index scheme cell, select one of the
following:
- Normal
- This scheme uses the traditional smn index. You can
specify TE-mode (s = 1) or TM-mode (s = 2) and the indices
M and N.
M is the mode index in the azimuth direction and N is the mode index in the radial direction and must be in the range 1, 2...∞.
Feko does not distinguish between even and odd modes (with and angular dependencies), but rather use the angular dependency . The index M can also be negative, but it must be in the range −N..N.
- Compressed
This scheme uses compressed one-dimensional mode numbering scheme. The J mode index is then specified in the index column. Here
where s = 1 for TE-modes and s = 2 for TM-modes.(1) This unified mode numbering scheme allows the computation of an extended scattering matrix (with network and radiation ports). The index J then represents a unique port number in the scattering matrix.
- In the Mag. sqrt(W) cell, specify the absolute value of the complex amplitude for the spherical mode. Due to the spherical modes normalisation, the amplitude unit is .
- In the Phase [deg.] field, specify the phase of the complex amplitude for the spherical mode.
- In the Label field, specify a unique label for the spherical modes data.
- Click Create to define the spherical modes data and to close the dialog.
