GET_STEP_INFO
Utility/Data Access SubroutineThis subroutine returns information about the current simulation step in a MotionSolve simulation.
Use
This function-style subroutine can be called from within any user-written subroutine to obtain information about the current simulation step for a MotionSolve model, or about the current solver step in a transient analysis. This utility can be used to check, for example, whether the current step is a predictor step, a corrector step or a converged step, for example. If this function is called during any other analysis, a value of -1 is returned.
Fortran Calling Syntax
call GET_STEP_INFO(FLAG)
C/C++ Calling Syntax
c_get_step_info(flag)
Python Calling Syntax
flag = py_get_step_info()
MATLAB Calling Syntax
flag = m_get_step_info()
Output
FLAG
[integer]
The integer value returned by this function:
0
Indicates the current step is a converged step.
1
Indicates the current step is a predictor step.
2
Indicates the current step is a corrector step.
-1
Indicates that the current analysis is not a transient analysis.
