GET_SPARSE_MATRIX_DATA
Utility/Data Access SubroutineReturns the data from a sparse Reference_Matrix element.
Use
The function can be called by any user subroutine. There is a separate function for a full Reference_Matrix element called GET_FULL_MATRIX_DATA.
Fortran Calling Syntax
CALL GET_SPARSE_MATRIX_DATA(id, rows, cols, vals, size, ierr)
C/C++ Calling Syntax
c_get_sparse_matrix_data(id, rows, cols, vals, size, ierr)
Python Calling Syntax
[rows, cols, vals, ierr] = py_get_sparse_matrix_data(id, size)
MATLAB Calling Syntax
[rows, cols, vals, ierr] = m_get_sparse_matrix_data(id, size)
Attributes
id
[integer]
Specifies the ID of the Reference_Matrix element.
size
[integer]
Specifies the size of the Reference_Matrix element.
Output
rows
[integer]
A "size" array containing row indices for values stored in vals.
cols
[integer]
A "size" array containing column indices for values stored in vals.
vals
[double precision]
A double precision array containing data from the Reference_Matrix element.
ierr
[integer]
An integer that specifies the status of the call to the GET_SPARSE_MATRIX_DATA as follows:
0
Normal return.
1
ID not found, call ignored.
2
Size does not equal the size of the Reference_Matrix.
