GET_NCONTACTS
Utility/Data Access SubroutineUsed to extract the number of rigid body contacts during the simulation.
Use
This subroutine can be used to extract the number of active rigid body contacts in MotionSolve
Fortran Calling Syntax
CALL GET_NCONTACTS(ID, I_GRA_ID, J_GRA_ID, NCONTACTS, ERRFLG)
C/C++ Calling Syntax
c_get_ncontacts(id, i_gra_id, j_gra_id, ncontacts, errflg)
Python Calling Syntax
[ncontacts, errflg] = py_get_ncontacts(id, i_gra_id, j_gra_id):
Attributes
ID
[integer]
The ID of the contact force modeling element (Force_Contact in the XML) for which the results are desired.
I_GRA_ID
[integer]
The ID of the I body's graphic representation.
J_GRA_ID
[integer]
The ID of the J body's graphic representation.
Output
NCONTACTS
[integer]
An integer value that represents the number of active contacts at the current time step.
ERRFLG
[logical]
A value that is true if an error occurs during the call to GET_NCONTACTS
  1. The GET_NCONTACTS utility function can only be used within a CONTACTPOST subroutine to retrieve the number of active contacts within the model at the current time step.
  2. This utility function is often called in conjunction with the GET_CONTACT_POST utility function.
