Find and Fill Cavities
Use the Plug tool to find and fill cavities. The Plug tool can also be used to remove protrusions, holes, and complex features.
You can interactively fill cavities using the guide bar or fill all cavities at once.
Explore the tools used to create geometry.
Explore the tools used to edit geometry.
Use the Split tools to create fixed points and split surfaces or solids using a variety of methods.
Use the Stitch tool to stitch and unstitch adjacent or overlapping surfaces, and suppress or unsuppress edges.
Use the Fillets tool to create a constant radius on lines, surfaces, and edges.
Use the Imprint tool to imprint geometry onto target surfaces or lines, thus creating new fixed points or edges.
Use the Boolean tool to combine solids, subtract one solid from another, detach solids, and find the intersection out of the solids.
Use the Cut Hole tool to generate holes in surfaces/2D mesh using various kind of shapes.
Use the Extract tool to convert sketches into geometry lines and surfaces with the realize option. Delete lines and surfaces converted from a sketch entity with the unrealize option.
In this section you will learn about updating CAD metadata and parameters.
Clean up problematic areas on geometry.
to define additional options.
| Option | Description |
| Automatic |
| Semi-Automatic |
