Use the Extract tool to convert sketches into geometry lines and surfaces with the realize option. Delete lines and
surfaces converted from a sketch entity with the unrealize option.
Use the Boolean: Detach tool to separate selected solids from
neighboring solids that share one or more common faces.
Shared or partition faces between selected solids and surrounding solids duplicate to
become bounding faces of the separated solids. Partitioning faces within the
selection are maintained after they are detached from the rest of the model.
From the Geometry ribbon, click the Boolean > Detach tool.
Select solids.
In the microdialog, select one of the following
options:
Option
Detach all
Selected solids detach from neighboring solids and
each other.
Detach from each other
Selected solids detach from each other
but maintain an interface with neighboring solids.
Figure 3.
Detach from not selected
neighboring solids while maintaining an interface within themselves.
