Use the Extract tool to convert sketches into geometry lines and surfaces with the realize option. Delete lines and
surfaces converted from a sketch entity with the unrealize option.
Imprint Geometry
Use the Imprint tool to imprint geometry onto target surfaces or lines, thus creating new fixed points or edges.
Combine, Subtract, Intersect, Detach Solids
Use the Boolean tool to combine solids, subtract one solid from another, detach solids, and find the intersection out of the solids.
Find and Fill Cavities
Use the Plug tool to find and fill cavities. The Plug tool can also be used to remove protrusions, holes, and complex features.
Cut Holes
Use the Cut Hole tool to generate holes in surfaces/2D mesh using various kind of shapes.
Extract Entities
Use the Extract tool to convert sketches into geometry lines and surfaces with the realize option. Delete lines and surfaces converted from a sketch entity with the unrealize option.
CAD Update
In this section you will learn about updating CAD metadata and parameters.
