Use the Extract tool to convert sketches into geometry lines and surfaces with the realize option. Delete lines and
surfaces converted from a sketch entity with the unrealize option.
Use the Imprint tool to imprint geometry onto target
surfaces or lines, thus creating new fixed points or edges.
Imprinting points on lines or surfaces creates geometry vertices similar to using the
Split: Interactive tool. Imprinting surfaces onto
surfaces imprints all of the source surfaces' edges onto the target surfaces.
The imprint direction is always normal to targets.
From the Geometry ribbon, click the Imprint tool.
Select imprint targets.
On the guide bar, activate the
Target selector. If the source geometry is
points/nodes, select whether to imprint onto lines or surfaces using the
drop-down menu.
Imprinting a node on a free line splits the line at the node
location.
Imprinting a node on a feature edge adds a fix point at the node
location.
Make your selection in the modeling window.
Select source geometry to imprint.
Source selector and choose whether to imprint
lines, nodes, points, or surfaces using the drop-down menu.
Optional: On the guide bar, click
to define imprint options.
Click Imprint.
The selected geometry is split. Lines are projected along the normal direction of
the selected surfaces.
Tip:
Split multiple surfaces with multiple lines at once.
Use the Split: Interactive tool to untrim previously
imprinted surfaces.
