stitch
The stitch connector is unique among connectors in that there is no inherent realization. It is designed to tie the mesh between its links.
Table 1. Stitch Connector Options
Option Description
Select a Parent Link Takes the lead link information from the selected item. In most situations, this can be left blank and it will be determined internally by the shape of the weld. For example, a T joint or a Lap joint.
After Stitch Realization options for how the mesh is tied together.
Keep Node IDs Describes how to maintain the best possible numbering of the end nodes when tying the two plates together.
Imprint Project Options Specifies the shortest projection or tangency to keep the shape of the plate if there is a shorter projection.
