Restriction: Only available in LS-DYNA.
This realization creates a single row of BEAM elements for the body.
Note: Use the
init_dyna_mat196.ini config file to set the default
attributes for the created MATL196 material.
This realization uses the
prop_dyna_matnum_seamarea.tcl post script
and the
weld_config.ini and
init_dyna_mat196.ini config file.
