rpti::item::tableofreference
Interact with items of type tableofreference.
upported property names
-name -value -parent
All properties available can be passed via the "create" API or modified on an existing item via the "set" API. After creation all the properties that applies for table type can be used.
rpti::item::tableofreference create
Creates an item of type "tableofreference".
For
Value: A full list of standard property names see Supported property name above.
Returns
The ID of the item type table or .tcl-error in case an error occurred during creation.
rpti::item::module create -name "My Module" -value {{A B C D} {2 2}} -parent $rootid value format : {{list data} {$numrows $numcols}}. data should match numrows X numcols
rpti::item::tableofreference delete
Deletes the item with the specified ID.
-id
Mandatory value: Item ID. The item ID which is returned by the corresponding "create" API.
Returns
1 for OK, .tcl-error in case of error.
rpti::item::tableofreference delete -id $id
rpti::item::tableofreference get
Queries the value of one property.
-id
For
Returns
The value of the specified property or .tcl-error in case of error.
rpti::item::tableofreference get -id $id -property parent
rpti::item::tableofreference getpropertyid
Queries ID of property.
-id
Value: Item ID.
-key
Value: Property key.
Returns
ardi::item::text set -id $id -name "My Text Item" -value "Good monring, how are you today?"
rpti::item::tableofreference getpropertykeylist
Queries list of properties
-id
Item: Item ID.
Returns
List of property keys for a particular item ID.
rpti::item::tableofreference set
Sets one or multiple parameters to specified values. The type of the item is assigned upon creation and cannot be changed after.
-id
For
Returns
rpti::item::tableofreference set -id $id -name "My Table of References" -value {{X Y 0.1 0.2} {2 2}} -parent $parentid
