rpti::item::module
Create or modify report modules.
rpti::item::module create
rpti::item::module create -config "HwLoop"
Supported Property Names
To set loop results properties, use the following:
name
Name
Value
String
hw_page Model
Model
Value
Page 1/Window 2
Page window source
comp_ids
Components
Value
list of component ids
group_ids
Sets
Value
list of set ids
add_displayed
Add displayed components
lcase_options
Load Cases
Value
Active, Last and Multiple
lcase_datalist
Selected Load Cases
Value
{simulationid subcasid}
{1 0}
exclude_hide_etype
Entity Type
Value
Sets and Components
Entity type for exclude and hide option
mask_set_ids
Enity Selection (Set)
Value
Set Ids
mask_comp_ids
Enity Selection (Components)
Value
Component Ids
exclude_etype
Entity Type
Value
ignore_element_set_ids
Entity Selection(Set)
Value
Set Ids
ignore_component_ids
Entity Selection(Component)
Value
Component Ids
ignore_num_layers
Number of Layers
Value
Integer
loop_start
Start loop with
Value
Component and loadcase
add_complete_overview
Overview for each loadcase
Value
0 or 1
Enable overview for each loadcase
exportopt
Export
Value
All, Above, Below, EqualTo and Overview
expcriteria
Export
Value
real number
Export Criteria Value
loop_over_hotspots
Loop Over Hotsport
Value
0 or 1
Enable loop over hot spots
split_table
Auto Split Table
Value
0 or 1
split_table_type
Split table by columns or rows
Value
Columns or Rows
Auto split table by row or column
split_rows
Maximum Rows
Value
Integer
split_cols
Maximum Columns
Value
Integer
