rpti::item::image
Interact with items of type image.
Supported Property Names
To set image properties, use the following properties:
label
Caption and Location of caption.
Value
String, Below Image/ Above Image.
hw_page
Model location
Value
Page 1/Window 2
hw_output
Output Type
Value
PNG/JPEG/TIFF, for HyperMesh and other clients
PNG/JPEG/TIFF/GIF/H3D, for HyperView and MediaView (in Document mode)
PNG/JPEG/TIFF/GIF/AVI/H3D, for HyperView and MediaView (in Presentation mode)
crop
Crop an image.
Value
0 or 1.
hw_best_view
Best view.
Value
0 or 1.
Enable or disable Best View
hw_view_modes
View mode.
Value
Isometric View, XY Top View, XY Bottom View, ZX Right View, XZ Left View, ZY Front View and YZ Rear View
Note: Applied only for HM/MV
HV view modes- Global View, Global Components,Global Regions, Global Spheres, Selection Transparency, Selection Isolate, Local Entity Zoom, Local Transparency, Local Contour, Isometric View, XY Top View, XY Bottom View, ZX Right View, XZ Left View, ZY Front View and YZ Rear View.
hv_enable_note
Create Note.
Value
0 or 1.
hv_note_on
Note Location.
Value
Maximum of Contour, Minimum of Contour and Hotspots of Contour.
hv_find_hotspots_at
Find Hotspots.
Value
Above Threshold and Below Threshold.
hv_hotspot_threshold
Threshold
Value
Number
hv_hotspot_distance
Zone Distance
Value
Number
hv_number_of_hotspots
Maximum Hotspots
Value
Number
hv_note_text
Note Text
Value
String
Value: { format %0.3f {entity.contour_max}}
hv_note_bg_color
Fill Color
Value
rgbcolor
"200 100 100"
hv_note_fill_color_mode
Fill Color Mode
Value
User, Component and Contour.
hv_note_text_color
Text Color
Value
rgbcolor
hv_note_text_color_mode
Text Color Mode
Value
User, Maintain Contrast, Component and Contour.
hv_note_align_text
Align Text
Value
Left, Center and Right.
hv_note_border_thickness
Border thickness
Value
Number (0-4)
hv_note_border_color
Border Color
Value
rgbcolor
hv_note_border_color_mode
Border Color Mode
Value
Border Color Mode
Value
hv_note_font_family
Font Family
Value
String
hv_note_font_style
Font Style
Value
Regular, Italic, Bold and Bold Italic
hv_note_font_size
Font Size
Value
Number
hv_note_transparent
Enable Transparency
Value
0 or 1
hv_note_shape
Note Shape
Value
Rectangle, Circle and Ellipse.
hv_note_position_to_attachment
Note Position To Attachment
hv_note_auto_hide
AutoHide
Value
0 or 1
hv_note_screen_anchor
ScreenAnchor
Value
0 or 1
hv_hide_local_system
Hide Local System
Value
0 or 1
hv_hide_modelinfo_note
Hide Model Info Note
Value
0 or 1
hv_auto_fit
AutoFit
Value
0 or 1
hv_legend_file
Legend file
Value
Valid legend file name with full path
hv_update_legend
Set Dynamic Legend
Value
0 or 1
hv_capture_option
Capture option.
Value
Legend and Graphics Area, Graphics Area and Legend only.
::rpti::item set -id $imageobid -label "My Image" -position "Above Image"
::rpti::item GetPropertykeylist
rpti::item::image create
Creates an item of type "image".
For
Value: A full list of standard property names see Supported property name above.
Returns
The ID of the item or .tcl-error in case an error occurred during creation.
rpti::item::image create -name "My Image Item"
rpti::item::image delete
Deletes the item with the specified ID.
-id
Mandatory value: Item ID. The item ID which is returned by the corresponding "create" API.
Returns
1 for OK, .tcl-error in case of error.
rpti::item::image delete -id $id
rpti::item::image get
Queries the value of one property.
-id
For
Returns
The value of the specified property or .tcl-error in case of error.
rpti::item::image get -id $id -property parent
rpti::item::image getpropertyid
Queries ID of property.
-id
Value: Item ID.
-key
Value: Property key.
rpti::item::image getpropertykeylist
Queries list of properties.
-id
Value: Item ID. The item ID which is returned by the corresponding "create" API.
Returns
List of property keys for a particular item ID.
rpti::item::image set
Sets one or multiple parameters to specified values. The type of the item is assigned upon creation and cannot be changed after.
-id
For
Returns
rpti::item::image set -id $id -name "My Image Item" -value "Good monring, how are you today?"
