rpti::item::chapter
Interact with items of type chapter. This item type is valid only for document reports.
Supported Property Names
-name-value-parent-type (read only)
All properties available can be passed via the "create" API or modified on an existing item via the "set" API.
rpti::item::chapter create
Creates an item of type "chapter".
For
Value: A full list of property names see Supported property name above.
Returns
The ID of the item or .tcl-error in case an error occurred during creation.
rpti::item::chapter create -name "My Chapter Item"
rpti::item::chapter delete
Deletes the item with the specified ID.
-id
Mandatory value: Item ID. The item ID which is returned by the corresponding "create" API.
Returns
1 for OK, .tcl-error in case of error.
rpti::item::chapter delete -id $id
rpti::item::chapter get
Queries the value of one property.
-id
For
Returns
The value of the specified property or .tcl-error in case of error.
rpti::item::chapter get -id $id -property parent
rpti::item::chapter getpropertyid
Queries ID of property.
-id
Value: Item ID.
-key
Value: Property key
rpti::item::chapter getpropertykeylist
Queries list of properties
-id
Value: Item ID.
Returns
List of property keys for a particular item ID.
rpti::item::chapter set
Sets one or multiple parameters to specified values. The type of the item is assigned upon creation and cannot be changed after.
-id
For
Returns
rpti::item::chapter set -id $id -name "My Chapter Item" -value "Good monring, how are you today?"
