rpti::item::property
Interact with items of type property.
Supported Property Names
-name -value -type(create only) -command -setcommand -validatecommand -visible -enabled
All properties available can be passed via the "create" API. Specific property can be set using "set" API, for example, command, setcommand, getcommand, validatecommand,help use getattributelist for complete list of attributes. Some of the attributes such as -command-getlistcommand are type specific. Queries list of available attributes.
-id
Value: Item ID. Not used.
rpti::item::property create
Creates an item of type "property".
-id
Mandatory value: Parent item ID of type text,image,table,module etc, \paren
-key
Mandatory value: Unique key/name for the property.
-name
Value: "Display name of the property, if not specified key is used as display name".
-type
(defaults to str): Type of property.
For
Value: A full list of standard property names see Supported property name above.
Returns
The ID of the item or .tcl-error in case an error occurred during creation.
rpti::item::property create -id $parentid -key "MyKey" -name "My Property" -value "My Value" -type "str"
rpti::item::property delete
Deletes the item with the specified ID.
-id
Mandatory value: Parent item ID of type text,image,table,module, and so on.
-name
Returns
1 for OK, .tcl-error in case of error.
rpti::item::property delete -id $id
rpti::item::property get
Queries the value of one property.
-id
Mandatory value: Item ID. The item ID which is returned by the corresponding "create" API.
For
Returns
The value of the specified property or .tcl-error in case of error.
rpti::item::property get -id $id -property parent
rpti::item::property set
Sets name and value of specific property.
-id
For
Returns
rpti::item::property set -id $id -setcommand "::setCommand" -command "::cmdcallback"
