rpti::frwk
Enables you to execute and export report.
rpti::frwk addconverter
Add converter class, used for version management.
class
Value: Class Name that implements conversion process.
rpti::frwk addcustompackage
Registers .tcl package to load containing custom module.
-directory
Value: Directory that contains .tcl package.
-packagename
Value: Name of .tcl package.
Returns
1 for OK; .tcl-error in case of error.
rpti::frwk addcustompath
Registers additional search path(s) to locate custom modules.
-directory
Value: One or a list of paths separated by blank.
Returns
1 for OK, .tcl-error in case of error.
rpti::frwk addview
Add/Register a view for update callbacks.
rpti::frwk addview
view
Value: View/widget that implements update callbacks.
rpti::frwk appendtemplate
Appends the specified report template to existing report template.
-file
Value: File name of report template.
Returns
rpti::frwk execute
Executes the current report template.
rpti::frwk execute
-id
Value: ID of the items to be executed.
The default value: "root" all items in the report will be executed.
Returns
1 for OK
rpti::frwk export
Exports the Ms-office report based on current report template.
rpti::frwk export
-file
Value: File name of Ms-office report including extension.
Returns
1 for OK, .tcl -error in case of error.
rpti::frwk geterrorcount
Get number of errors.
None
rpti::frwk getexportitems
Get number of items marked for export.
None
rpti::frwk getinterface
Get Frwk Interface.
-name
Value: Report session name.
Returns
Framework Interface Object
rpti::frwk getmasterdocument
Queries the current Ms-office master template file based on current report format (document, presentation).
Returns
The current Ms-office master template file.
rpti::frwk getreporttype
Queries the Ms-office report type.
Returns
The current Ms-office report type (word, ppt).
rpti::frwk getunexecuteditems
Get number of non-executable items.
None
rpti::frwk getworkdir
Queries the current work directory.
Returns
The current work directory.
rpti::frwk ispaused
Check if report execution is paused.
rpti::frwk ispaused
rpti::frwk::isrunning
Check if report is running.
rpti::frwk isrunning
rpti::frwk isstarted
Check if report execution started.
rpti::frwk loadtemplate
Loads the specified report template.
-file
-filelist
Value (optional): List of file names as seen in the Report Template dialog or as passed or as used in the order of running HyperWorks in batch mode. See HyperWorks documentation "barchmode" parameter "-tplParams".
Returns
rpti::frwk newreport
Creates new report template.
-type
Value: Type of report (word, ppt).
Returns
rpti::frwk pause
Flags pause execution.
rpti::frwk pause
rpti::frwk quit
Quits Report.
rpti::frwk quit
None
Returns
rpti::frwk redraw
Notifies all registered views to redraw itself.
rpti::frwk redraw
rpti::frwk registertype
Register a new type relating to an editor.
-type
Value: Unique one-word, all lowercase identifier for the new type. This is the identifier you will need to specify in the module's .xml file.
-class
Value: ITcl class that contains the editor code. Make sure to use proper name space for your custom editor to avoid naming clashes.
Returns
rpti::frwk removeview
Remove already registered views.
view
Value: View/widget registered.
rpti::frwk reset
Resets the execution flags.
rpti::frwk reset
rpti::frwk resume
rpti::frwk resume
rpti::frwk savetemplate
Saves the current report template.
-file
Returns
rpti::frwk setmasterdocument
Sets the Ms-office master template based on current report format (document, presentation).
-file
Value: Ms-office master template file.
Returns
rpti::frwk setworkdir
Sets the work directory to specified path.
-directory
Value: Path of work directory.
Returns
rpti::frwk start
Starts ARD in desired mode.
rpti::frwk start
-mode
Values: Interactive (interactive with GUI) mute (engine only, no GUI).
Returns
rpti::frwk startexec
Flags execution start.
rpti::frwk stop
Flags stop execution.
rpti::frwk stop
rpti::frwk templateloadpostcommand
Specify the callback to be called after a new report template got loaded.
-command
Value: Command, .tcl procedure or ITcl method to be called.
Returns
rpti::frwk templateloadprecommand
Specify the callback to be called before a new report template is being loaded.
-command
Returns
rpti::frwk validate
Validate an item.
rpti::frwk validate
-id
Value: Specify item ID to validate.
