Stamping
A stamping constraint should be used when the manufacturing process calls for stamping rather than casting.
A stamping constraint can be applied from the part context menu.
![](../../../images/figures/inspire/stamping.png)
This type of constraint should be used when the manufacturing process calls for stamping rather than casting. When you run an optimization on a design space with a stamping constraint applied, the solver returns a result with uniform thickness while avoiding negative draft angles and internal voids.
When applying a stamping constraint, you may also specify the No Hole option in the microdialog to eliminate internal voids. Stamping constraints are valid for optimization but not analysis.
Apply a Stamping Constraint
Click on a design space and use the context menu to apply a stamping constraint.
Microdialog Options
Double-click a shape control to edit it and access the microdialog options.
Icon | Description |
Apply Draw Direction | Click to convert the stamping constraint to a different type of draw direction. |
Eliminate internal voids in the optimized part. |
Flip the draw direction. |
Rotate the shape control. |
Align a shape control to a design space after moving it. By default, shape controls are aligned to capture the most likely orientation for that particular design space as it is oriented in space. |
Align a shape control to the global axes. |
Stamping Examples
![](../../../images/figures/inspire/Stamp_Draw_Design_Space.png)
Figure 1. Design Space
![](../../../images/figures/inspire/Stamp_Draw_Result.png)
Figure 2. Optimized Shape with Stamping Applied
![](../../../images/figures/inspire/Stamp_Draw_Result_No_Hole.png)
Figure 3. Optimized Shape with Stamping Applied and No Holes
