Optimization will find the most effecitve design for each design space in a model in response to the applied loading
conditions on that model. You can run several different types of optimization including topology, topography,gauge,
lattice, and PolyNURBS shape optimization.
View the status of the current run, as well runs for the current model that have not yet been viewed. To see all past
runs, you need to view the run history.
Set up and run a topology, topography, gauge, or lattice optimization.
Optimization Overview
Optimization will find the most effecitve design for each design space in a model in response to the applied loading conditions on that model. You can run several different types of optimization including topology, topography,gauge, lattice, and PolyNURBS shape optimization.
Run Optimization
Define and run a topology, topography, gauge, or lattice optimization using the Run Optimization tool.
Show Optimization Results
View and compare optimization results, view design violations, and explore the generated shape.
Run Status
View the status of the current run, as well runs for the current model that have not yet been viewed. To see all past runs, you need to view the run history.
Run History
View, sort, open, and delete past runs for the current and previous models.
