/TRANSFORM/SCA
Block Format Keyword Defines a scale for a node group with defined scale center and scale factor.
| /TRANSFORM/SCA/transform_ID/unit_ID | |||||||||
| transform_title | |||||||||
| grnd_ID | FscaleX | FscaleY | FscaleZ | node_IDc | |||||
| transform_ID | Transformation
| unit_ID | Unit Identifier (Integer, maximum 10 digits) |
| transform_title | Transformation
| grnd_ID | Node group identifier.
4 (Integer) |
| FscaleX | X scale factor. Default = 0.0 (Real) |
| FscaleY | Y scale factor. Default = 0.0 (Real) |
| FscaleZ | Z scale factor. Default = 0.0 (Real) |
| node_IDc | Center node
identifier. (Integer) |
- The node node_IDc is the scale center.
- If the node node_IDc is not defined, the origin (0,0,0) will be used as scale center.
- The scaling is done in the global frame.
- Transforms applied to node groups only transform the nodal coordinates. Material directions for orthotropic materials and boundary conditions such as initial velocity, imposed movement are not transformed.
