/SPHCEL
Block Format Keyword Describes the SPH cells.
/SPHCEL/part_ID | |||||||||
node_ID |
Field | Contents | SI Unit Examples |
part_ID | Part
identifier. (Integer, maximum 10 digits) |
node_ID | Supporting node
identifier. (Integer) |
- The particles will have the same identifier as their supporting node.
- The particles should be distributed with respect to a hexagonal compact net or a cubic net (refer to SPH Cells Distribution).
