/PROP/TYPE46 (SPR_MUSCLE)
Block Format Keyword This property describes a user-defined elasto-visco plastic material using user-defined functions to describe time dependent active and passive behavior for tension and (force versus deflection or force versus strain time and visco plastic and elastic).
/PROP/TYPE46/prop_ID/unit_ID or /PROP/SPR_MUSCLE/prop_ID/unit_ID | |||||||||
prop_title | |||||||||
Mass | Stiffness | Vel_max | Force | Xk | |||||
fct_ID1 | fct_ID2 | fct_ID3 | fct_ID4 | Idens | |||||
Damp | EPSI | ||||||||
Scale_t | Scale_x | Scale_v | Scale_F |
prop_ID | Property
unit_ID | Unit Identifier (Integer, maximum 10 digits) |
prop_title | Material
Mass | Element mass, or element
density depending on Idens
flag. (Real) |
or |
Stiffness | Initial element stiffness
(for initial time step calculation). (Real) |
Vel_max | Maximum velocity or strain
rate. (Real) |
or |
Force | Initial
force. (Real) |
Xk | Contact
stiffness. Default = initial element stiffness (Real) |
fct_ID1 | Time dependent scale
function identifier (factor versus time). (Integer) |
fct_ID2 | Scale function identifier
(depending on EPSI: (default = 0) factor versus
strain or factor versus elongation). (Integer) |
fct_ID3 | Scale function identifier
strain rate or factor versus velocity). (Integer) |
fct_ID4 | Function identifier for
(depending on EPSI: (default = 0) force versus
strain or force versus displacement). (Integer) |
Idens | Mass input variable
flag.
(Integer) |
Damp | Damping
coefficient. (Real) |
EPSI | Deflection calculation
flag.
(Integer) |
Scale_t | Scale factor for abscissa
(time) for fct_ID1. (Real) |
Scale_x | Scale factor for abscissa
(elongation) for fct_ID2 , if EPSI =
1. (Real) |
Scale_v | Scale factor for abscissa
for fct_ID3. If EPSI = 1: velocity If EPSI = 0: strain rate (Real) |
or |
Scale_F | Scale factor for ordinate
(force) for fct_ID4. (Real) |
Example (Muscle)
#RADIOSS STARTER
/UNIT/2
unit for prop
g mm ms
/PROP/SPR_MUSCLE/2/2
MUSCLE
# Mass Inertia Vel_max Force XK
.001 .02 0.005 0.25 .1
# fct_ID1 fct_ID2 fct_ID3 fct_ID4 Idens
1 2 3 4 1
# Damping EPSI
0.00 1
# scalet scale_X scale_V scale_F
1 1 1 1.0
/MOVE_FUNCT/1
scaling function 5
1.0 0.1 0.0 0.0
/FUNCT/1
Force_vs_Time (active)
# time scaling factor
0.0000 0.00000000
0.9000 0.00000000
1.0000 1.00000000
2.0000 5.00000000
3.0000 5.00000000
4.0000 2.00000000
5.0000 2.00000000
6.0000 2.00000000
7.0000 2.00000000
8.0000 2.00000000
9.0000 10.00000000
10.0000 10.00000000
11.0000 2.00000000
12.0000 2.00000000
13.0000 12.00000000
14.0000 12.00000000
15.0000 12.00000000
20.0000 2.00000000
29.0000 0.00000000
30.0000 0.00000000
/FUNCT/2
Force_vs_Elongation (active)
-1.0 1.00000000
0.0 0.00000000
1.0 1.00000000
# 0.100000000E+10 1.00000000
/FUNCT/3
Force_vs_Velocity (active)
-0.100000000E+1 2.00000000
0.00 0.00000000
10.000 2.00000000
20.000 1.00000000
30.000 1.00000000
/FUNCT/4
Force_vs_Elongation (passive)
-1.0 -3.00000000
0.0 0.00000000
1.0 3.00000000
#ENDDATA
- Total force is:
(1) Where, ,
are functions fct_ID1, fct_ID2, fct_ID3 and fct_ID4
