/NODE
Block Format Keyword Defines the coordinate of node, which is fundamental unit of graphic in structure.
| /NODE/unit_ID | |||||||||
| node_ID | Xc | Yc | Zc | ||||||
| unit_ID | Unit Identifier. (Integer, maximum 10 digits) |
| node_ID | Node
identifier. (Integer) |
| Xc | X
coordinate. (Real) |
| Yc | Y
| Zc | Z
- Nodes may be defined with more than one block.
