Engine Keyword Initial time step for nonlinear implicit
analysis.
/IMPL/DTINI
Field |
Contents |
SI Unit Exampke |
Initial implicit time
step. |
- Initial time step determines initial
loading increment in this run session. This key should be defined in nonlinear
analysis.
