/IMPL/DT/1
Engine Keyword Implicit time step control method 1.
/IMPL/DT/1
lt_w L_dtn
lt_w | If the solution of a time
step converges within It_w iterations, the next
time step will be increased by a factor of
Scale factor for
increasing the time step.
L_dtn | Maximum number of
iterations before resetting and decreasing the time step by a factor
of
Scale factor for
decreasing the time step.
- If /IMPL/DT/1, /IMPL/DT/2, or /IMPL/DT/3 are not present, the only time step controls are /IMPL/NCYCLE/STOP and /IMPL/DT/STOP. In the case of divergence, the time step will be reduced by half and repeated.
