/H3D/TRUSS
Engine Keyword Generate H3D contour output results for /TRUSS truss elements.
/H3D/TRUSS/Keyword3
#optional next line(s) that lists the parts to save results for.
part_ID1 ... part_IDN
/H3D/TRUSS/VONM
/H3D/TRUSS/ENER
356 293
Keyword3 | Output types. 3 | |
part_IDN | Optional list of part IDs for which results will be output. |
- The syntax /H3D/ELEM/Keyword3 is also valid.
- When PART IDs are listed after the /H3D/TRUSS line the specified results will only be output for those parts.
- The scalar output is defined below.
Table 1. Scalar Output Keyword3 Description AMS Elements using AMS timestep due to /DT/CST_AMS. DT Element timestep. ENER Specific energy density (internal energy divided by the element mass). EPSP Plastic strain. F1 Force in local coordinate system. - F1
- Force in X direction
FORC All forces and moments in local coordinate system. F1, F2, F3, M11, M21, M31, M12, M22, M32
MASS Element mass. OFF Element status. Where the result output is:- = -1
- Element is not active (it is defined in an activated rigid body).
- = 0
- Deleted element.
- Between 0 and 1
- Under failure process.
- = 1
- Active element.
SIGX Stress in specified direction. VONM von Mises stress.
