/H3D/BEAM
Engine Keyword Generate H3D contour output results for /BEAM beam elements.
/H3D/BEAM/Keyword3/Keyword4/Keyword5
/H3D/BEAM/VONM
/H3D/BEAM/ENER
356 293
- The syntax /H3D/ELEM/Keyword3/Keyword4/Keyword5 is also valid.
- When PART IDs are listed after the /H3D/BEAM line, the specified results will only be output for those parts.
- The output types are outlined in the
tables:
Table 1. Scalar Output Keyword3 Keyword4 Keyword5 Description AMS Elements using AMS timestep due to /DT/CSdT_AMS. DT Element timestep. ENER Specific energy density (internal energy divided by the element mass). EPSP NPT=I or ALL Plastic strain. The integration point output NPT is only available for /PROP/TYPE18 (INT_BEAM). F1, F2, F3 Force in local coordinate system. - F1
- Force in X direction
- F2
- Force in Y direction
- F3
- Force in Z direction
FORC All forces and moments in local coordinate system. F1, F2, F3, M11, M21, M31, M12, M22, M32
M11, M21, M31, M12, M22, M32 Moment in local coordinate system. - M11
- Moment in X at node 1
- M21
- Moment in Y at node 1
- M31
- Moment in Z at node 1
- M12
- Moment in X at node 2
- M22
- Moment in Y at node 2
- M32
- Moment in Z at node 2
MASS Element mass. OFF Element status. Where the result output is:- = -1
- Element is not active (it is defined in an activated rigid body).
- = 0
- Deleted element.
- = 1
- Active element.
SIGX, SIGY, SIGZ, SIGXY, SIGYZ, SIGZX Stress in specified direction. VONM von Mises stress. FRACTION MARTENSITE NPT= i or ALL Martensite fraction. Only available for /MAT/LAW71 + /PROP/TYPE18 (INT_BEAM).
TMAX Maximum martensite phase fraction over time and over integration points. Only available for /MAT/LAW71 + /PROP/TYPE18 (INT_BEAM).
Table 2. Tensor Output Keyword3 Keyword4 Keyword5 Description TENS STRESS NPT= i or ALL Stress tensor for /PROP/TYPE18 (INT_BEAM). (component XX, XY, ZX in elementary coordinate system)
STRAIN NPT= i or ALL Strain tensor for /PROP/TYPE18 (INT_BEAM). (component XX, XY, ZX in elementary coordinate system)
MAX Maximum strain over all integration point (per element) max of each component XX, XY, ZX. TMAX Maximum strain over all integration points and over time (per element) max of each component XX, XY, ZX. - The output location in
Keyword4 can be defined via:
NPT = integration points
- Output can be requested for a specific location number (I), ALL. The output locations are separated by a forward slash (/) and can be in any order.
