/FXINP
Engine Keyword Generates input files for flexible bodies from eigenmodes and static modes computation.
/FXINP
EIGID1 CDAMP1 ITYP1
EIGIDN CDAMPN ITYPN
EIGID1 … EIGIDN | Identification number of
eigenmodes and static modes computation problem defined in Radioss Starter (/EIG). The corresponding flexible body will have the same support as that defined in the /EIG. Local reduction modes for this flexible body will be those requested in the /EIG. If static modes are requested, they will be orthogonalized with respect to mass matrix. |
CDAMP1 … CDAMPN | Critical structural
damping coefficient. It is used to compute Rayleigh damping coefficients to be used on the flexible body from the lowest and the highest local eigen frequencies. (Real) |
ITYP1 … ITYPN | Computed flexible body
type. A flexible body is either fully free or fully blocked. See
Flexible Body Input File for details about IBLO variable.
