/DEL/Eltyp/1
Engine Keyword Delete element numbers N1first to N1last, . . ., NIfirst to NIlast.
/DEL/Eltyp/1
N1first N1last ... NIfirst NIlast
Eltyp | Element type:
N1first ... N1last | First and last element number of a range to delete. |
- For element numbers, it is possible to enter several lines.
- Elements with void material cannot be deleted.
