/EOS/NASG
Block Format Keyword Describes the NASG (Noble-Abel-Stiffened-Gas) equation of state.
/EOS/NASG/mat_ID/unit_ID | |||||||||
eos_title | |||||||||
b | q | ||||||||
Psh | P0 | Cv |
mat_ID | Material
identifier. (Integer, maximum 10 digits) |
unit_ID | Unit Identifier. (Integer, maximum 10 digits) |
eos_title | EOS
title. (Character, maximum 100 characters) |
b | Covolume. (Real) |
Heat capacity ratio
. (Real) |
Stiffness
parameter. (Real) |
q | Heat
bond. (Real) |
Psh | Pressure
shift. (Real) |
P0 | Initial
pressure. (Real) |
Cv | Heat capacity at
constant volume. (Real) |
Reference
density. Default = material density (Real) |
/UNIT/1
unit for mat
kg m s
/MAT/HYDRO/7/1
WATER
# RHO_I RHO_0
957.74 0
# NU PMIN
0 0
/EOS/NASG/7/1
Noble-Abel-Stiffened-Gas EoS for WATER (O.Le Metayer, R.Saurel)
# b GAMMA PSTAR Q
6.61E-4 1.19 7028.00E+5 -1177788
# Psh P0 Cv Rho0
0.0 1.0453E5 3610 957.74
/EULER/MAT/7/1
#enddata
- NASG EOS
(Noble-Abel-Stiffened-Gas equation of state) is based on the Stiffened-Gas
and Noble-Abel equation of states.
(1) Where,- Specific volume
- Co-volume
- Heat capacity at constant volume
- Temperature
This EOS summarizes in a simple formulation two main molecular effect:- Agitation
- Attractive/Repulsive effects
The previous form can be written in form.
Where, ; .
This gives
- Some comparisons with other
EOS:
Noble-Able NASG Stiffened-Gas - The Initial State is
calculated from the input parameters:
from
Where,from
Where, - Enthalpy can be calculated
(2) - The
parameter can be calculated
with:
(3) Where, is the speed of sound in the material.
- Equations of state are used by
Radioss to compute the hydrodynamic pressure and are
compatible with the material laws:
- /MAT/LAW3 (HYDPLA)
- /MAT/LAW4 (HYD_JCOOK)
- /MAT/LAW6 (HYDRO or HYD_VISC)
- /MAT/LAW10 (DPRAG1)
- /MAT/LAW12 (3D_COMP)
- /MAT/LAW49 (STEINB)
- /MAT/LAW102 (DPRAG2)
- /MAT/LAW103 (HENSEL-SPITTEL)
Liquid Phase | Vapor Phase | |
Cp | 2608.0 | 2063.0 |
Cv | 2393.0 | 2016.0 |
1.09 | 1.02 | |
1159.0e+5 | 0.0 | |
7.51e-4 | 0.0 | |
−794696.0 | −2685610.0 |
Reference state for the liquid phase:
Valid temperature range: [300 - 500 K]
Cp | 4285.0 | 1401.0 |
Cv | 3610.0 | 955.0 |
1.19 | 1.47 | |
7028.0e+5 | 0.0 | |
6.61e-4 | 0.0 | |
-1177788.0 | 2077616.0 |
Validity: T in [300 - 500 K]
