Optimization Keyword This keyword can be used to select a response as the objective function of an optimization run by selecting a response
as the objective function. The selected response can either be minimized or maximized based on the inputs
specified on this keyword.
Optimization Keyword In this group, keywords are used to define
the design constraints.
/DCOMP Optimization Keyword Defines manufacturing constraints for composite sizing optimization.
/DCONSTR Optimization Keyword This keyword constrains a design response by specifying its lower and upper bounds. The response is defined by a /DRESP1 entry.
