Optimization Keyword Defines Bulk Format Data to be used as the conversion data for Radioss material data (/MAT) into the intermediate OptiStruct input file during Design Optimization.
Optimization Keyword Defines Bulk Format Data to be used as the conversion data for Radioss property data (/PROP) into the intermediate OptiStruct input file during Design Optimization.
Optimization Keyword This keyword can be used to select a response as the objective function of an optimization run by selecting a response
as the objective function. The selected response can either be minimized or maximized based on the inputs
specified on this keyword.
Optimization Keyword This group of keywords are used to insert Bulk
format data into <name>.radopt file.
/BULK Optimization Keyword Defines Bulk Format data to be inserted into the intermediate OptiStruct deck during Design Optimization.
/BULKFMT Optimization Keyword Defines the Format of the intermediate OptiStruct input file during Design Optimization.
/BULKMAT Optimization Keyword Defines Bulk Format Data to be used as the conversion data for Radioss material data (/MAT) into the intermediate OptiStruct input file during Design Optimization.
/BULKPROP Optimization Keyword Defines Bulk Format Data to be used as the conversion data for Radioss property data (/PROP) into the intermediate OptiStruct input file during Design Optimization.
