/CLOAD
Block Format Keyword Defines a concentrated force or moment applied to each node of a prescribed nodal group.
/CLOAD/cload_ID/unit_ID | |||||||||
cload_title | |||||||||
fct_IDT | Dir | skew_ID | sens_ID | grnd_ID | Ascalex | Fscaley |
cload_ID | Concentrated load block identifier (Integer, maximum 10 digits) |
unit_ID | Unit Identifier (Integer, maximum 10 digits) |
cload_title | Concentrated load block title. (Character, maximum 100 characters) |
fct_IDT | Time function
identifier. (Integer) |
Dir | Direction of load: X, Y, and Z for forces; XX,
YY, and ZZ for moments. (Text) |
skew_ID | Skew identifier. (Integer) |
sens_ID | Sensor identifier.
(Integer) |
grnd_ID | Node group to which the concentrated loads are
applied. (Integer) |
Ascalex | Abscissa scale factor. Default = 1.0 (Real) |
Fscaley | Ordinate scale factor. Default = 1.0 (Real) |
- The direction of load must be right justified in the ten characters of field number 2.
- The grnd_ID input is
obligatory. The concentrated loads will only be applied to the nodal group. The force is applied
to each node individually, so:
(1) with being the number of nodes in the node group.
- The
Ascalex and
Fscaley are used to scale the abscissa and
ordinate.The actual load function value is calculated as following:
(2) Where, is the function of fct_IDT.
The force is applied individually to each node of the nodal group. The total force is equivalent to the force value multiplied by the number of nodes.
