/BEAM
Block Format Keyword Describes the beam elements. Two properties (/PROP/TYPE3 (BEAM) and /PROP/TYPE18 (INT_BEAM)) are available for this beam element. The properties describing a beam element are all defined in a local beam coordinate system.
/BEAM/part_ID | |||||||||
beam_ID | node_ID1 | node_ID2 | node_ID3 |
Field | Contents | SI Units Example |
part_ID | Part identifier of the
block. (Integer, maximum 10 digits) |
beam_ID | Element
identifier. (Integer) |
node_ID1 | Node identifier
1. (Integer) |
node_ID2 | Node identifier
2. (Integer) |
node_ID3 | Node identifier
3. (Integer) |
- The identifier (ID) must be unique in each element family, but it is advised for each element type to have a unique element identifier in the global model.
- More than one beam block may be used to define a part.
- Any number of beams may be defined in one block.
- Local coordinate system of beam:
Nodes 1 and 2 define local X-axis.
Nodes 1, 2 and 3 define local axis (X,Y) plane at time t =0.
The third node is only used to define initial local frame position.
Z axis is orthogonal to (X,Y) plane.
