Automatic Penalty Lagrange
Block Format Keyword Same behavior as interface TYPE7 with possible switch to Lagrange multiplier formulation; if minimum constant time step (defined with /DT/INTER/CST) is reached.
| Contact Treatment | Types | Application | Description | |
| Automatic Penalty Lagrange | Slide / Void | /INTER/LAGDT/TYPE7 | Solid contact impact at all speeds | Same behavior as TYPE7 with constant minimum time step. |
- When
formulation switches to Lagrange multiplier, the same limitations apply:
- Lagrange multiplier interfaces are compatible with all Lagrange multiplier kinematic conditions.
- Lagrange multiplier interfaces are not compatible with other kinematic conditions.
- Lagrange multiplier interfaces are not compatible with SPMD parallel version.
