/ADMAS
Block Format Keyword Assign additional non-structural mass to nodes or a group of nodes. Optionally the total additional non-structural mass of a part or a group of parts can be defined (applied to shells and solids only) or a surface mass can be assigned to a surface and Radioss would then compute the added node based mass value using area (volume) - weighted distribution.
| /ADMAS/type/admas_ID/unit_ID | |||||||||
| admas_title | |||||||||
| Mass | grnd_ID | ||||||||
| Mass/Area | surf_ID | ||||||||
| Mass | grpart_ID | IFLAG | |||||||
| Mass1 | node_ID1 | ||||||||
| Mass2 | node_ID2 | ||||||||
| etc | etc | ||||||||
| MassN | node_IDN | ||||||||
| Mass1 | part_ID1 | IFLAG | |||||||
| Mass2 | part_ID2 | IFLAG | |||||||
| etc | etc | IFLAG | |||||||
| MassN | part_IDN | IFLAG | |||||||
| type | Input type.
| admas_ID | Added mass block
identifier. (Integer, maximum 10 digits) |
| unit_ID | Unit Identifier. (Integer, maximum 10 digits) |
| admas_title | Added mass block
title. (Character, maximum 100 characters) |
| Mass | Added
mass. (Real) |
| Mass/Area | Added mass per unit
area. (Real) |
| grnd_ID | Node group to which the
mass is added (Integer) |
| surf_ID | Surface to which the mass
per unit area is added. (Integer) |
| grpart_ID | Part group to which the
mass is added. (Integer) |
| node_IDN | Node to which the mass is
added. (Integer) |
| part_IDN | Part to which the mass is
added. (Integer) |
| IFLAG | Flag to switch between
area weighted distribution and volume weighted distribution of the
added mass to parts).
(Integer) |
- This option cannot be used in a 2D axisymmetrical analysis.
- Final mass replaces structural mass and final mass for each node must be greater than structural mass. In other words, non-structural mass for each node must be greater than zero. The element time step is not affected by the addition of non-structural mass since the nodal time step changes.
- Using /ADMAS additional mass and final mass is in the part level and the node level, not in the element level.
- Area or volume weighted distribution of the mass does not account for density of components (referred to the part-group). Therefore, for reasonable distribution of the mass, it is advisable to have the same material and property definition in components of the part group.
