rbe3-celas1-rbe3
View new features for HyperWorks 2021.1.
Use the Connector Browser to view and modify connectors in the current model.
Use the Control Manager to create and edit the various types of controls that will be used later when realizing connectors.
Use the tools in the Create tool set to create connectors, assign controls, and realize.
View details for different types of realizations.
A list of realization types that can be specified for point connectors.
FEMFAT spotwelds are a particular realization type that conforms to the specifications outlined in the FEMFAT fatigue software.
A list of realization types that can be specified for fastener connectors.
A list of realization types that can be specified for line connectors.
A list of realization types that can be specified for area connectors.
Organize elements into connector groups.
The FE configuration file (feconfig.cfg) is used to define custom welds such as ACM (Area Contact Method) and other special types.
Attachments are an entity to facilitate the ease of joining subsystems.
Create weld points at a predefined pitch distance so that the model build process can continue without the need to wait for the published weld data from CAD. Autopitch is useful when working with elements, not geometry.
HyperMesh composites modelings.
