View new features for HyperWorks 2021.1.
HyperMesh composites modelings.
From the Preferences menu, you can access the Options dialog.
Display options are set in the Options dialog.
Set general application options such as showing the splash screen or the getting started screen at startup, showing icon labels, whether to scale the user interface, and picking a theme color.
Set display options such as background color, foreground color, and mesh lines.
Set element mark options and general visualization options.
Set various general performance options, as well as control the Display Acceleration Block (DAB).
Set light sources for illuminating graphics. Lighting settings control the location, direction, and intensity (high/low) of the specular lighting.
Set and customize mouse controls.
A new workflow emphasizing upfront data loading for standard crash post processing use cases.
ON THIS PAGE
ON THIS PAGE
