Create and edit user-defined data type expressions, derived load cases, and systems. You can also plot a forming limit
diagram, generate streamlines, track entities during animation, and create and import/export sets of entities.
Query entities, create or edit free body diagrams, construct multiple curves and plots from a single result file, and
create and plot stress linearization.
The Image Plane tool allows you to select and overlay images (such as company logos, watermarks, etc.) or videos in the
graphics area for correlation and presentation purposes.
Select and overlay images or videos in the modeling window for
Image Planes
The Image Plane tool allows you to select and overlay images (such as company logos, watermarks, etc.) or videos in the graphics area for correlation and presentation purposes.
