Solver Differential Equations
Use the Diff Equations tool to set solver differential equations. These equations can be used to add additional states to the mechanical system being modeled.
View new features for HyperWorks 2021.1.
HyperMesh composites modelings.
MotionView is a general pre-processor for Multi-body Dynamics.
Create and edit systems, assemblies, and analyses, use wizards to build models quickly, create and edit belt/pullies, NLFE stabars, and NLFE springs, access the EDEM and Track Builder tools.
Create and edit points, bodies, lines (curve graphics), solids (graphics), markers and vectors, edit grounded/ungrounded bodies, create and edit rigid body groups, configure gravity, and select material properties.
Create and edit various model entities.
Use the Joints tool to create and edit basic joints.
Use the Motions tool to create motions and to edit the initial conditions, displacements, velocities, and acceleration of joints.
A Coupler entity defines an algebraic relationship between the degrees of freedom of two or three joints.
Use the Gears tool to create a gear entity to relate the motion of two joints.
Use the Advanced Joints tool to create and edit a set of special constraints called higher pair joints. Typically, these are constraints that involve a curve or surface on at least one of the two bodies.
Use the Spring Dampers tool to edit the connectivity, properties, and initial conditions of springs and dampers.
Use the Bushings tool to create bushings and edit their connectivity, properties, and orientation rules.
Use the Beams to create beams and edit their connectivity, properties, and orientations.
Use the PolyBeams tool to create polybeams and edit their points and properties.
Use the Forces tool to create forces and to edit the orientation and properties of forces.
Use the Contacts tool to specify the attributes of a contact force between two bodies.
The Contact Properties Editor macro enables you to edit multiple contact force entities in a model simultaneously.
Use the General Constraints tool to create a generic expression based constraint.
Use the Fields tool to create a compliant connection between two bodies where stiffness or damping in one direction can be a function of displacement in another direction
The Modal Forces tool allows you to include a disturbed force on a flexible body that exists in the modal form in the flexible body H3D.
Use the Spline2D/Curves tool to create and edit curves.
The Spline3D panel allows you to add and edit three dimensional spline data.
Use the Variables tool to create solver variables that can be used to create an algebraic expression of state variables, as well as other solver variables. This can then be referenced in function expressions throughout the solver input file.
Use the DataSets tool to create and edit datasets comprised of object types, such as real, string, boolean, integer, and options.
Use the Arrays tool to create solver arrays and set solver array data. Solver array types include X array, Y array, U array, IC array, Plant Input array, and Plant Output array.
Use the Strings tool to create a solver string and set solver string data. A solver string provides a string that can be accessed within the model, for example, to pass into a user subroutine.
Use the Sensors tool to sense an event during simulation and to define a response to that event
Use the SISOs tool to set control SISO data. This data can be used to add additional states to the mechanical system being modeled.
Use the FMU tool to add a Functional Mock-up Unit and connect it to a multi-body model.
Use the State Equations tool to create and set control state equation data.
Create and edit outputs, create and edit templates, run the solver, view reports, access the Load Export utility, use the Optimization Wizard, open HyperStudy, utilize many pre-processing and post-processing capabilities with regards to flexible bodies (or flexbodies), run MS/EDEM cosimulation in batch mode, and generate H3D from EDEM.
MotionView has many pre-processing and post-processing capabilities with regards to flexible bodies, or flexbodies, for multi-body dynamics models.
From the Preferences menu, you can access the Options dialog.
Reference material for the HyperWorks Desktop scripting interface which is a set of Tcl/Tk commands.
ON THIS PAGE
ON THIS PAGE
