HyperWorks
HyperWorks
2021.1
  1. Home
  2. Multibody Modeling
  3. MotionView Ribbons
  4. Model
    Create and edit various model entities.
  5. Modal Forces
    The Modal Forces tool allows you to include a disturbed force on a flexible body that exists in the modal form in the flexible body H3D.
  • What's New
  • Get Started
  • Video Tutorials
  • Manage Files and Data
  • Sessions and Report Templates
  • Model Build and Assembly
  • Geometry
  • Meshing
  • Elements
  • Morph
  • Connectors
  • Composites
  • Crash and Safety
  • Airbag Solutions
  • Design Space
  • Design Explorer
  • Aerospace
  • Aeroelasticity
  • Certification
  • Marine
  • Squeak and Rattle Director
  • Geomechanics Director
  • Panels
  • Results Data
  • Plot Data
  • Multibody Modeling
  • Media Files
  • Text Files
  • Tabulate Results
  • Publishing and Reporting
Index
HyperWorks
2021.1
HyperWorks
  • What's New
    View new features for HyperWorks 2021.1.
  • Get Started
  • Video Tutorials
  • Geometry
  • Meshing
  • Elements
  • Morph
  • Connectors
  • Composites
    HyperMesh composites modelings.
  • Crash and Safety
  • Airbag Solutions
  • Design Space
  • Design Explorer
  • Aerospace
  • Aeroelasticity
  • Certification
  • Marine
  • Panels
  • Results Data
  • Plot Data
    • MotionView Overview
      MotionView is a general pre-processor for Multi-body Dynamics.
    • Model Browser
    • MotionView Ribbons
      • Assembly
        Create and edit systems, assemblies, and analyses, use wizards to build models quickly, create and edit belt/pullies, NLFE stabars, and NLFE springs, access the EDEM and Track Builder tools.
      • Geometry
        Create and edit points, bodies, lines (curve graphics), solids (graphics), markers and vectors, edit grounded/ungrounded bodies, create and edit rigid body groups, configure gravity, and select material properties.
      • Model
        • Joints
          Use the Joints tool to create and edit basic joints.
        • Motions
          Use the Motions tool to create motions and to edit the initial conditions, displacements, velocities, and acceleration of joints.
        • Couplers
          A Coupler entity defines an algebraic relationship between the degrees of freedom of two or three joints.
        • Gears
          Use the Gears tool to create a gear entity to relate the motion of two joints.
        • Advanced Joints
          Use the Advanced Joints tool to create and edit a set of special constraints called higher pair joints. Typically, these are constraints that involve a curve or surface on at least one of the two bodies.
        • Spring Dampers
          Use the Spring Dampers tool to edit the connectivity, properties, and initial conditions of springs and dampers.
        • Bushings
          Use the Bushings tool to create bushings and edit their connectivity, properties, and orientation rules.
        • Beams
          Use the Beams to create beams and edit their connectivity, properties, and orientations.
        • Polybeams
          Use the PolyBeams tool to create polybeams and edit their points and properties.
        • Forces
          Use the Forces tool to create forces and to edit the orientation and properties of forces.
        • Contacts
          Use the Contacts tool to specify the attributes of a contact force between two bodies.
        • Contact Properties Editor
          The Contact Properties Editor macro enables you to edit multiple contact force entities in a model simultaneously.
        • General Constraints
          Use the General Constraints tool to create a generic expression based constraint.
        • Fields
          Use the Fields tool to create a compliant connection between two bodies where stiffness or damping in one direction can be a function of displacement in another direction
        • Modal Forces
        • Spline2D/Curves
          Use the Spline2D/Curves tool to create and edit curves.
        • Spline3D
          The Spline3D panel allows you to add and edit three dimensional spline data.
        • Solver Variables
          Use the Variables tool to create solver variables that can be used to create an algebraic expression of state variables, as well as other solver variables. This can then be referenced in function expressions throughout the solver input file.
        • Datasets
          Use the DataSets tool to create and edit datasets comprised of object types, such as real, string, boolean, integer, and options.
        • Solver Arrays
          Use the Arrays tool to create solver arrays and set solver array data. Solver array types include X array, Y array, U array, IC array, Plant Input array, and Plant Output array.
        • Solver Strings
          Use the Strings tool to create a solver string and set solver string data. A solver string provides a string that can be accessed within the model, for example, to pass into a user subroutine.
        • Sensors
          Use the Sensors tool to sense an event during simulation and to define a response to that event
        • Control SISOs
          Use the SISOs tool to set control SISO data. This data can be used to add additional states to the mechanical system being modeled.
        • Functional Mockup Unit (FMU)
          Use the FMU tool to add a Functional Mock-up Unit and connect it to a multi-body model.
        • Control State Equations
          Use the State Equations tool to create and set control state equation data.
        • Solver Differential Equations
          Use the Diff Equations tool to set solver differential equations. These equations can be used to add additional states to the mechanical system being modeled.
      • Analyze
        Create and edit outputs, create and edit templates, run the solver, view reports, access the Load Export utility, use the Optimization Wizard, open HyperStudy, utilize many pre-processing and post-processing capabilities with regards to flexible bodies (or flexbodies), run MS/EDEM cosimulation in batch mode, and generate H3D from EDEM.
    • MotionView CAD Interfacing
    • Flexible Bodies
      MotionView has many pre-processing and post-processing capabilities with regards to flexible bodies, or flexbodies, for multi-body dynamics models.
    • Preferences Menu
      From the Preferences menu, you can access the Options dialog.
    • Vehicle Modeling
    • Tcl/Tk Reference Guide
      Reference material for the HyperWorks Desktop scripting interface which is a set of Tcl/Tk commands.
    • MDL Reference Guide
    • MotionSolve Reference Guide
    • Templex and Math Reference Guide
    • MotionView Python Reference Guide
  • Media Files
  • Text Files
  • Tabulate Results
View All Altair Simulation Help
HyperWorks
HyperWorks
2021.1
  1. Home
  4. Model
  5. Modal Forces
  • What's New
  • Get Started
  • Video Tutorials
  • Geometry
  • Meshing
  • Elements
  • Morph
  • Connectors
  • Composites
  • Crash and Safety
  • Airbag Solutions
  • Design Space
  • Design Explorer
  • Aerospace
  • Aeroelasticity
  • Certification
  • Marine
  • Panels
  • Results Data
  • Plot Data
  • Media Files
  • Text Files
  • Tabulate Results
Index
Modal Forces
Create Modal Forces
  1. From the Project Browser, select the system to which the Modal Force entity is to be added.
  2. Right-click on a system in the Project Browser and select Add > Force Entity > ModalForce from the context menu.
    OR
    Right-click on a modal force folder in the Project Browser and select Add ModalForce from the context menu.
    OR
    From the Model ribbon, click the arrow next to the Entities tool set name, then select Modal Forces.
    The Add ModalForce dialog is displayed.
  3. Specify a label for the force.
  4. Specify a variable name for the force.
    By default, variables names of entities in MotionView follow a certain convention. For example, all modal force entities have a variable name starting with “mfrc_”. This is the recommended convention to follow when building models in MotionView since it has many advantages in model editing and model manipulation.
  5. Click OK to close the window or Apply to continue creating entities.
    Note: In order to add a distributed force on a flexible body, the force needs to be included in the flexible body H3D during the CMS flex body generation process. The force can be a generic force on a set of nodes, or a pressure load on a set of elements or a thermal loading.
    Once the force is available in the flexible body, the force can be scaled with regard to time or a solver function expression using the Properties tab.
    Once a modal force entity has been added to the model, the panel for the force will automatically be displayed in the panel area.
Edit Modal Forces
Define the Connectivity of Modal Forces
From the Connectivity tab, select the flexible body on which the distributed force should be applied.
  1. If the Modal Force panel is not currently displayed, select the desired modal force by clicking on it in the Project Browser or in the modeling window.
    The Modal Force panel is automatically displayed.
  2. Click the FlexBody collector and select the flexible body on which the distributed force is to be applied from the modeling window, or double click the collector to open the Model Tree (from which the desired body can be selected).
  3. Select the force type from the drop-down menu.
    For the MotionSolve solver mode, this force can be applied only as an action only force. For the ADAMS solver mode, the force can also be applied as action reaction. In this case, an additional option to specify a rigid body as reaction body is available.
  4. If Action Reaction is chosen as the force type, click the RigidBody collector and select a rigid body as a reaction body for the distributed force from the modeling window or Model Tree.
Define the Properties of Modal Forces
From the Properties tab, the load case that is available in the flexible body H3D can be selected and a scale factor can be applied.
  1. Select the method of scaling for the modal force from the drop-down menu.
    If Linear is chosen, enter a real number in the value field to specify the constant scale.
    If Curve is chosen, define the scale in the form of a curve.
    1. Select AKIMA, CUBIC, LINEAR , or QUINTIC under Interpolation as the method of interpolation of between two data points on the curve.
    2. Enter a value under Independent variable.
    3. Resolve the curve by double-clicking the Curve collector and selecting a curve from the Select a Curve dialog.
      Note: To use a curve, you first need to define a curve using the Curves panel.
    If Spline3D is chosen, define the scale as a function of two independent variables in the form of a three dimensional spline data.
    1. Select AKIMA, CUBIC, LINEAR , or QUINTIC under as the method of interpolation of values between 2 data points in XY plane.
      The interpolation choices are applicable to Independent variable X only. Data along Independent variable Z is linearly interpolated.
    2. Resolve the 3D spline by double-clicking on the Spline3D collector and selecting a Spline3D entity from the Select a Spline3D dialog.
      Note: To use a Spline3D entity, you first need to define a spline using the Spline3D panel.
    3. Specify an expression for Independent variable X and Independent variable Z.
    If Expression is chosen, define the scale in the form of a solver function.
  2. Select the load case from the drop-down menu.
    The list contains the load case id as available in the flexible body H3D. Load case ID generally matches with the ID specified in the finite element deck (.fem in case of OptiStruct) that was used to generate the flexible body.
Use User-Defined Properties for a Modal Force
If desired, define the modal force using the User-Defined tab, which will allow you to specify the properties of the force using user subroutines.
  1. From the Connectivity tab, click the User-defined properties check box.
    The Properties tab is removed.
  2. Click the newly added User-Defined tab.
  3. Define the user subroutine.
    1. Provide an expression with the USER solver function with parameters being passed to the user subroutine.
    2. Alternatively, activate the Use local file and function name check box to specify a local file where the subroutine code can be accessed by the solver.
      If this option is not specified, MotionSolve will search for a subroutine following its user subroutine loading rules.
    3. Select a function type from the drop-down menu.
    4. Select the local file for the subroutine.
      The type of file to be specified will depend on the selected function type. For example, if DLL/SO is selected, you can specify a file with a .dll extension (for Windows) or an .so extension (for Linux).
    5. Specify the function name in the subroutine that defines the entity, or accept the default name provided by HyperWorks.
