These files can be read into a pre-processor, such as
HyperMesh, or into a CAD tool to view the deformed
geometry.
Note: Only unscaled coordinates are exported. If scaled coordinates
are needed, use the
Linear Superposition utility in
HyperView to create a
subcase, and then use this utility to export the solver deck (with scaled
coordinates). To create a derived loadstep from a simulation list, refer to
Derived
Load Cases.
